What do you guys think of this hardware. It is a build for a customer, a budget system and i am wondering what you guys think of this motherboard and processor? keep in mind I am trying to keep things as inexpensive as possible.
ASUS P5VD2-VM SE LGA 775 VIA P4M900 Micro ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211162
Intel Celeron 440 Conroe-L 2.0GHz 512KB L2 Cache LGA 775 Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116038
Western Digital Caviar SE WD1600AAJS 160GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136075
A-DATA Value Series 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Dual Channel Kit Desktop Memory - Retail
LG Black 18X DVD+R 8X DVD+RW 10X DVD+R DL 18X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache IDE 18X DVD±R DVD Burner with LightScribe - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136127
COOLER MASTER Elite RC-330-KKR1 Black SECC ATX Mid Tower Computer Case 350W Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119118
ASUS EAX1550/TD/256M Radeon X1550 256MB 128-bit GDDR2 PCI Express x16 Video Card - Retail
Supporting Hypermemory up to 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121059
Subtotal: $311.93
The customer is looking for a build thats not such a "staggering economic investment." She is really looking to purchase one of those $499 dell machines and believes custom built pc's with industry standard parts is inferior to dell or hp's lol.
This build should run pretty well, I dont think itll be running vista - the celeron probably wouldn't run well on vista, so most likely XP. That is pretty much the most I can spend on hardware considering xp will run $100 and my profit margine will be very very low - I know this doesn't seem like much - however she does run a office with about 10 pc's and if shes impressed with the machine which im assuming she will be with 2 gigs of ram and a 160 gig sata drive, she will upgrade her systems through me as opposed to dell.
Any suggestions or recommendations would be appreciated, I tried to explain one gig would work fine on xp theres no need for two, However being that 2 is pretty much the industry standard right now, im gonna go with two, leaves room to upgrade to vista later.
Subtotal: $311.93
