Imagine that you go out to buy groceries or whatever and leave your computer on(but blocked with password login) in your room.
Imagine your roommates are some sneaky bastards, Is there any way to configure XP to record the password tries that were entered at any time? also, is it possible to limit the number of tries when entering the password in the login screen?
for example: you limit the number of tries to 3, if all the tries fail then the computer blocks itself for say 30 minutes of whatever, then when you come back from buying groceries you can check if someone tried to get into your system and what wrong passwords they entered.
what do you think? is any of this possible with XP?
