Plaese Help! ASAP!!!
Well that type of lag usually comes from an internet connection problem. Are you using wireless or an ethernet cable? Do you use a router, or is your computer connected directly to the modem? Do you download things often? All these things could be causeing the thing you are describing.
I use a router, but this never happend before and i am the main or first computer connect via ethernet cable. The other 3 devices are connected wireless. Like i said i never had a problem before (last year or so) so i never botherd to check who else was online. Right now i'm the only one connected and i am still getting that lag effect if i play. Download things often? Never during game play.
The other computers could be doing something that slows down the other computers, ie. downloading something. Try shutting down the other computers, and trying MOAAA. If it still lags a lot, you ISP could just be working on the network.
The other computers are all offline. I was able to check my fps during gameplay. It's mostly in the 30-40's, but very unstable sometimes it's in the 60-70fps area(not very often but it has spiked this high for a moment), and sometimes it's dropping down to below 10! Now that i have the fps shown on my screen, i can see that when i am experiencing that lag or whatever my fps are also real low. Any ideas?
Earlier today i was on the computer playing MOHAA and went to get a drink, i closed everything and just the desktop was showing. I was gone for about 2 minutes because i had a quick pee too. When i came back my computer desktop/screen was messed up! There was colored vertical and horizontal lines flashing all over the screen and the keyboard and mouse didn't work. I restarted the compter, it booted up like normal and everything was okay. I was surfing the net for about a half hour and then i got hungry and wanted to go to mcdonalds, so i closed all windows and just the desktop was on then go to mcdonalds quickly. When i get back the screen was black and my girlfriend said it was beeping when i was gone. I restarted it and it booted fine. It never did this before. Any ideas?
thats crazy I don't think spyware would do that but does anybody think it could?
