Computer Build Help
Wakaba >.<
I have already gotten a little info on this from chupacabra but decided to start my own thread....
The build i am looking for is strictly for gaming, and i have been looking and vigorgaming.com for the build for a few reasons.
1) I have only read good reviews from this company
2) They offer a 3 Year Warranty on parts and a lifetime warranty on service
3) I dont want to mess anything up trying to put this badboy together >.<
I have a few questions......
1) i just read that using RAID0 will not improve gaming performance. Is it worth using RAID mirroring to back up my files or just use one big hard drive? is any RAID setting going to help gaming performance/information access?
2) I read that the MOBO i have listed will only run dual video cards at a bandwidth of 8..something instead of using one card running at 16. is this true and if so, is it better to use one card at 16 or 2 crappier cards at 8??
3) Will these components work well together?
4) How will games run if Im using this tv as a monitor .. and which should i use to connect for best resolution?
Sony Bravia
PROCESSOR Intel Core 2 Quad-Core Processor Q6600 at 2.40GHz, 1066MHz FSB, 2X4M Cache
RIG Vigor Cooler Master CM 690 Screwless Chassis
RIG STYLE Top and Side 120MM Fan w/Deep Blue Lighting
RIG COOLING Vigor MonsoonTM II LITE TEC Active CPU Cooling System
RIG POWER Tagan TG800-U25 EasyCon XL nVidia-SLI Certified 800Watt Power Supply
MB CORE LOGIC Asus P5N-E-SLI NVIDIA nForce 650i SLI Intel Quad Core Ready
MEMORY 4GB Corsair TWIN2X2048-6400C4PRO X 2 DDR2 800MHz Memory with LED (4 X 1024MB)
HARD DRIVE 1 500GB S-ATA II 7200 RPM Hard Drive
HARD DRIVE 2 None.
RAID SETTING None.
VIDEO CARD (SLI SLOT 1) nVidia GeForce 8800 Ultra 768MB Xtreme Edition @650MHz, DVI and
TV Out
OPTICAL DRIVE 1 SONY/NEC Internal SATA AD7170S 18X Dual Layer DVD+/- RW + CDRW
Rewritable Drive
OPTICAL DRIVE 2 SONY/NEC Internal SATA AD7170S 18X Dual Layer DVD+/- RW + CDRW
Rewritable Drive
RECORDING SOFTWARE Bundled DVD/CDRW Software
SOUND Digital High Definition 3D 7.1 8-Channel Sound
NETWORK PORT Onboard Gigabit (10/100/1000Mbps) PCI Network Card
I/O PORTS 1 Parallel, 1 Game/Midi, 1 IEEE 1394 Firewire and 6 to 10 USB ports (Varies by
Motherboards)
KEYBOARD Standard Black Internet Multimedia Keyboard
MOUSE Standard Black Optical Wheel Mouse
FLOPPY DRIVE 1.44MB 3.5" Floppy Drive
OPERATING SYSTEM Microsoft Windows Vista Home Basic 32-bit w/Original DVD
SERVICE Standard 3 Year Limited Parts and Life-Time Labor Warranty
Price: $2453.00
Thanks for the help
IMO configuring raid0 is pointless, the sata drives transfer data at 3gb/s which is more than enough.
I don't really see why you'd need an SLI config for gaming, a single 8800gts is more than youll need for a few years. Unless you are doing some really intense video editing or things of those nature I think a single video card should be good enough. save the $$.
In my opinion, the whole set up is over priced (way over priced)
Firstly, the 32-bit OS that they offer will not recognize the 4GB RAM that they put in there. This is because 32-bit OS can only see a maximum of 3.12GB. So you might want to change the RAM to just 2GB (it's enough to play recent games) or if you really have to have a maximum RAM, get 3GB (so that would be 2x1GB + 2x512MB)
The sound card looks like an onboard to me... Another reason to say the build is overpriced. Also, there is no point in getting a SLI motherboard if you are only using one video card.
The following is a build that I have come up with, I was trying to go as close as I can to the build that you posted.
Cooler Master 690 (I believe this is the same case, not sure though)
http://www.newegg.com/product/product.asp?item=N82E16811119137
GIGABYTE GA-P35-DS3R
http://www.newegg.com/product/product.asp?item=N82E16813128050
MSI GeForce 8800Ultra (this card is factory overclocked and cheaper than the rest)
http://www.newegg.com/product/product.asp?item=N82E16814127288
PC Power & Cooling Silencer Quad 750W (I know its only 750W compared to your 800W but this PSU will be more than enough for the whole rig)
http://www.newegg.com/product/product.asp?item=N82E16817703009
Intel Core 2 Quad Q6600 (Hopefully you will get the G0 stepping as it will run cooler)
http://www.newegg.com/product/product.asp?item=N82E16819115017
Note: if you want a guaranteed G0 stepping, buy this processor from ClubIT as they guaranteed a G0 stepping for their Q6600.
Arctic Cooling Freezer 7 Pro 92mm CPU cooler
http://www.newegg.com/product/product.asp?item=N82E16835186134
CORSAIR XMS2 2GB (2 x 1GB) DDR2 800 (PC2 6400)
http://www.newegg.com/product/product.asp?item=N82E16820145034
Western Digital 500GB Sata 3.0 Gb/s
http://www.newegg.com/product/product.asp?item=N82E16822136073
Logitech G15 Gaming Keyboard (what more can I say... its a good gaming keyboard)
http://www.newegg.com/product/product.asp?item=N82E16823126179
Logitech MX518 2-Tone Gaming mouse
http://www.newegg.com/product/product.asp?item=N82E16826104178
Samsung 20x DVD+R, 20x DVD-R (x2, just to follow your build)
http://www.newegg.com/product/product.asp?item=N82E16827151153
Creative Sound Blaster X-Fi XtremeGamer
http://www.newegg.com/product/product.asp?item=N82E16829102006
Microsoft Windows Vista Home Premium 32-bit OS
http://www.newegg.com/product/product.asp?item=N82E16832116202
Total price: $1,838.87 w/o shipping and mail-in rebate
Hope I didn't miss anything. When you are done with this, you rig will be the sweetest ever. :D:D:D
that sounds awesome! thanks for the help. I changed out the PSU for the one offered in a combo on the bottom of the hard drive page. Just to make sure, the mobo is vista compatible correct? and is the Intel Core 2 Duo E6850 G0 Stepping Conroe 3.0GHz 4MB L2 LGA 775 better than the quad mentioned above? whats the difference?
Nope. Core 2 Duo is 2 cores. Quad is 4 cores...
Budget? I'd like to give it an go.
RAID0 increase the speed on Read/Write on HDD. Should increase the performance, theoretically, but may not be significant enough for you to notice when gamming. Also, if you use P2P software, I will not suggest you use RAID0, it 'harm' both HDD at the same time.
650i chipset run SLi with PCI-E x8, if you want both run at 16, get 680i
32bit OS works up to 3GB RAM. Get the 64bit if you need to run more RAM
I personally haven't try connecting PC with TV, so no idea. But I do have concern with the respone time of TV compare to the gaming LCD Monitor.
daisymtc, thanks for noobin it up for me, just what i needed :)
about the core and quad difference, i was wondering about performance differences...advantages (when used in gaming computer)
I dont believe i will be using p2p programs....they are like music download programs and stuff like that right? i will just be running games on this comp, nothing else. shouldnt have to worry bout it messing up raid0 right?
2)oh and is it possible to have an external usb harddrive that can back up all my info? and if one HDD does fail, can i stripe the info back again with the external drive after replacing the faulty HDD? the main purpose behind my build is to build a high powered game pc that i wont be stressing the hell out of, so i dont need to worry too much about burning out components. thanks again :)
I wouldn't go with a quad core unless you are doing some heavy video editing or very thread intensive apps. one of the higher speed core 2 duos will have plenty of power.
which will yield better performance? can i not overclock a quad Q6600 to 3.3 and have it performing better than the duo? they are about the same price, so why not go with the quad if its better?
Yes. Get the Q6600 here. You'll need thermal paste and an aftermarket heatsink/fan if you plan to overclock.
thanks! thats where i was gonna get it :) for the guaranteed g0 stepping. already have a heatsink in mind as well.....just wondering, whats the diff between OEM and Retail CPUs on that site/any site??
With OEM, you only get the processor - no box or stock HSF. With retail, you get the fancy retail box, cool Intel sticker, HSF, and installation instructions. It looks like all you need is the OEM product. :)
