Birthday - New case
taylormsj
My birthday is on the 30th, and since i have screwed up my current case with a jigsaw, im looking into a new case.
I want it to be big !! by this i mean id like it to be long so there is a bit of distance between the edge of the motherboard and the HDD cages.
My mum said she didnt want to spend loads on it, and said around the £50 mark, buti think i could get a bit more.
Ive looked at the antec P182 and it looks great, and i know the 900 cools well but im not sure if i want to get one.
I want something clean, want to be able to route cables behind the mobo tray too
Im in the UK
overclocker.co.uk and ebuyer.com are good sites if any americans want to help me
thanks
Im in the UK
thanks
If you want something big, do not get the 900. There's not a lot of room between the mobo and HD cages.
The P180 isn't actually that roomy inside. The two chamber design takes up a lot of room, and the difficult cable routing makes the case seem really crowded. Take a look at the thermaltake Shark, it's a VERY nice case.
im leaning towards the P182 or a gigabyte 3d aurora. The P182 has hole sin mobo tray and room behind for cable managment, and if i got a big graphics card id just take out the hdd cage as i only have one HDD.
I was thinking about going down the cheap road again, but now i think i want something that is quality, and not make me want to drill and cut it
