I have a newer HP that came with a 320 gb SATA drive. Can I add a second PATA drive to be used for data? If so, how are the different cables connected? Is there a Master/Slave switch to worry about? Thanks for any help.
Thanks for the info.
There is a ribbon cable that goes into my CD drive. Can I use the extra slave connector off this to connect into the PATA drive?
mep916,
I just got done putting it in, and it was very easy and works perfectly. Your advise was great. Thanks for helping.
No problem. Use your extra storage space wisely.![]()
I wish I were smart enough!![]()
