Help with a build
jg101987
I was hoping for some advice here.
Tell me what you think and (if applicable) anything I should change.
I'm trying to build the best PC possible for $800.
I've never built one on my own before. My custom one I have now was build with the help of a friend.
____________________________________________
LITE-ON 20X DVD±R Burner With 12X DVD-RAM Write - Black -$32.99
APEVIA X-CRUISER-BK Black Steel ATX Mid Tower Computer Case Retail - $64.99
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model - $279.99
Patriot Extreme Performance 4GB(4 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) - $144.99
XFX MB-N650-IUL9 LGA 775 NVIDIA nForce 650i Ultra ATX Intel Motherboard - $99.99
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - $69.99
Broadway Com Corp Okia-black-650 ATX 650W Power Supply - $54.99
EVGA 512-P2-N747-LR GeForce 8500GT 512MB 128-bit GDDR2 PCI Express x16 HDCP Ready SLI Supported Video Card - $94.99
Grand Total: $837.92
+ 50.00 shipping
I would like to try to keep the total around $850-900. But I do want to build the best and fastest one I can for the money.
Thanks in advance for any help.
_______________________________________________________
Here is what I want it to look like:
A few things I would look at.
You can get better RAM Cheaper after rebate. http://www.newegg.com/Product/Product.aspx?Item=N82E16820145034
Recertified Raptors..http://www.newegg.com/Product/Product.aspx?Item=N82E16822136067 Super fast configured in RAID 0.. Great value.
http://www.clubit.com/product_detail.cfm?itemno=A1938460&cmp=OTC-pricewatch Cheaper price on CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
CHEAPer memory... Same thing, $9 less.
Wow. Only 8MB cache, and ATA150 doesn't make it better.
