I give up, out with the old in with the new! ! !
bernie66
Hi guys, I've given up on my current laptop, its old an so id thought id upgrade an so im looking for a new laptop. I use it mainly for browsin the web, work, storing music, the usuall really nothin too much like downloading films or playing games. Therefore, i would like you all to help me find a decent laptop, speed is important as i hate to wait for things to load.
So, what do you all think??
Thanks
Fair enough m8y, few things...
Whats your budget? This is one of the main things you need to know when buying summin like this. How much you want/need to spend.
Where are ya from? There is no point recommending a shop of place to buy a computer if your miles away from the location.
Your idea on a product? The info you have given is great but I can think of a million types of laptops that would match the info given. You must have something in mind? or a shop (locally or via the internet) that you would go to when you are going to buy the laptop.
Have a look at the things above and then reply, this will help us zero in on the laptop you are after.
My Budget is £500. I live in manchester so currys, comet, dixon, pc world etc are shops i can get too.
Ive had bad experience with packard bell laptops so that out of the running unless you can prove otherwise.
I like the sony laptops, quite petite and light weight, dont want a heavy bulky thing like my toshiba at the moment. Id like to run more than one software at a time without it slllllloooooooooowwwwwwiiiiiiiinnnnnngggg on me.
Basically, a speedy, reasonable memory, with wi-fi etc good looking laptop and also the a laptop that you enjoy using without urging to throw it out of the window when it slows down etc.
Have a look at the ADVENT 8315
Specs:
The new Advent 8315 is great value, with a powerful Intel Core 2 Duo T5300 processor, allowing you to run multiple applications simultaneously. The 8315 is packed with top features including Genuine Windows Vista (R) Home Premium, 2GB memory and 120 GB hard drive.
# Intel Core 2 Duo T5300 Processor
# 1.73GHz, 533MHz FSB, 2MB Cache
# Genuine Windows Vista (R) Home Premium
# 2GB Memory
# 120GB Hard Drive
# DVD ReWriter MultiDrive
# 15.4" Widescreen Display
# 128MB Intel UMA 950 Graphics
# Wireless Enabled
# Up to 3 Hours
Can pick that up at PC world for £449.99
Yeah they are nice and look great but buying one new with decent specs will cost you more then £500 :(
what specs exactly do i need to be looking at for example how much GB of RAM etc if i want a speedy laptop with decent memory and one that wont slow down on me after a month or so???
To be honest, PC world's customer service is appauling so i think ill go with another shop and pay the extra £50
Thanks for that tho.
If you stick with 2gb of ram that should be plenty for a speedy laptop. Any laptop won't slow down after a month or so unless the user messes it up.
