Need Help with a Seagate Barracuda 200gig HD
zthechosen1
For the last few months i have been having no problems with my seagate barracuda ata 200gig drive, just recently it has decided to completely stop working. I am able to see the device during the bios and the boot sector but when i attempt to open the device "F:\ is not accessible the file or directory is corrupted or unreadable" If anybody can help i surely would appreciate it
System Specs
Hard Drive Type: SEAGATE BARRACUDA ATA 200 GIG
software: Windows Xp sp2
Motherboard: Lan Party UT
RAM: 1 GIG
i ran both the short and long diagnostic test, and the drive passed both
short test
Ran Diagnostics
Nvidia nForce 3 SATA
This Drive Supports Security Features
SMART is supported but disabled
Logging Feature Set is not Supported
Long Test
Device is 48 bit addressed
Should the drive be changed from 48 bit addresed to 32 bit addressed?
Is this a seperate HDD from where your boot drive is? Or is it a partition on your main hard drive?
If it is a partition, then it most likely has become corrupted. If it is your main hard drive, then having it as a F:\ drive instead of a C:\ drive could cause some problems, but since it has worked up till now?
If it is a seperate drive from your main drive, then it has either become corrupted, or the port you have it plugged into on your motherboard has gone bad. Try changing where it plugs into on your board.
There is always the possibility that this drive has just died. But with today's drives, that is not the most likely problem.
General System Information:
Total Physical Memory (bytes): 1,073,201,152
Used Physical Memory: (bytes): 647,536,640
Maximum Page File Size: (bytes): 2,580,033,536
Current Page File Size: (bytes): 568,147,968
Disk Geometry Information for Disk 1: 30515 Cylinders, 255 Heads, 63 Sectors/Track
System PartSect # Boot BCyl Head Sect FS ECyl Head Sect StartSect NumSects
0 0 80 1 0 1 0F 1023 254 63 16,065 490,207,410
Info: Begin C,H,S values were large drive placeholders.
Info: End C,H,S values were large drive placeholders.
Actual values are:
0 0 80 1 0 1 0F 30514 254 63 16065 490207410
16,065 0 00 1 1 1 07 1023 254 63 16,128 490,207,347
Actual values are:
16065 0 00 1 1 1 07 30514 254 63 16128 490207347
Disk Geometry Information for Disk 2: 9039 Cylinders, 255 Heads, 63 Sectors/Track
0 0 80 0 1 1 07 1023 254 63 63 145,195,407
Actual values are:
0 0 80 0 1 1 07 9037 254 63 63 145195407
Disk Geometry Information for Disk 3: 25841 Cylinders, 240 Heads, 63 Sectors/Track
0 0 00 0 1 1 07 1023 254 63 63 390,700,737
The drive itself looks ok, does it show up in computer management->disk manager? And if it does what does it look like? (ie unknown partition, raw, etc)
^^^^i dont understand the question.....but it shows up as local disk (F:) is not accessible the message i receive the file is corrupt or unreadable
Down at the bottom it will say something like this, or just take a screenshot and post it up
It seems as if though the drive was somehow erased without me doing so here are a few of the stats from Computer Management. Is there anyway i can recover my files or should i just go ahead and reformat the drive?
When i right click i am able to select the option to mark partition as active should i do this?
STATS
It says Healthy
layout: partition
Type: Basic
File System: (Blank)
% Free: 100
okay i tried reformating my drive and at the very end it said it wasnt able now when i click on the drive it says parameter incorrect
