Is lower cpu/mobo temps normal after overclocking
speedysim313
I just finished overclocking my Pentium D 3.4ghz cpu to 3.74ghz. When i checked the temp before overclocking it was averaging cpu:47C and mobo:39C. After overclocking it dropped cpu: average 36C and mobo: average 36C. also chassis fan speed was at 15000 rpms before overclocking and after about 8000 rpms is this because of the lower temp? Also would like to know what the CPU cooling System Thermal Resistence is??
Visionman Tower Gladiator Black
Orion Power Supply AC Input 100-120 V ac/ 200-240 V ac
ABIT IP-95 Motherboard
Intel Pentium D 945 3.4 GHz Dual Core 4mb/ Running at 3.74GHz
2x Elixir 512mb DDR2
GeForce 7300 GS 256mb
Western Digital 250 GB Hard Drive
Lite-On Light Scribe DVD-RW
Windows XP Professional
Got that motherboard to :D Nice!. No fan will run at 15k RPM. The temp should NOT drop, but instead raise..
ya that sounds kinda shady...heat should rise abit when overclocking....are you sure you overclocked?and what temp software are you using..?
