Broken Computer! :/
lee18041990
the other night i was downloading (left it on overnight) and it started squealing about 6 in the morning and sed it had malfunctioned in the middle of the night, the screen went bright blue and black!!!
so i switched it off!! and left it till after college the next day.
i switched it back on and it logged on, then the screen when purple/blue and fuzzed, then it switched off!! :/
it will not switch back on now!!
its not the psu as i have tried a diffrent one!
spec:
Monitor: dell
Motherboard: Dell 5150 Standard
Processor: Pentium(R) 4 CPU 3.20GHz
Memory: 2.00 Gb RAM DDR2
Graphics Card: Nivedia 8600GTS
Sound Card: Sound Blaster Augiey
Headphones: Razer Barracudda HP-1
Keyboard: Logitect G11
Mouse: Razer Diamondback Acid Green
Mouse Pad: Razer Mantis Control
Hard Drive: 160GB
any help would be great!
any beeping coming from motherboard.
when you press the power do the fans turn on? if not it has to be psu or mobo
check everything is plugged in correctly and all expansion cards taken out and reseated, probably wont help but worth a shot
i belive its the motherboard, there is a green light always on indide the computer, on the motherboard! cant say ive herd any beeping tho . . .
Ok then I have a 20 pin PSU which I haven't used it for once also.Now I want to sell it.It came bundled with my case.So will the same procedure works if I want to make sure wether it(PSU) works or not?
it will make sure that the psu works in a basic sence, the psu could still be failing in terms of voltage or current output. But its a good short term indicator
You could combine a jump starts with a multimeter to get the voltage outputs
