Da Mail Man
greetings,
before anyone says anything,this is NOT about pirating anything!
....now that we have that out of the way, i have a home made audio cd (sorta a "greatest hits") which was burned with nero.
......it seems that there is a fault in 2 of the songs/tracks that are on the cd. can i extract the "good" non-defective songs from that cd to a folder to be re-copied onto another cd after replacing the defective track(s)? (how?).
......also, if i did that, is it a matter of drag and drop to nero's "compilation window" to be burned or more involved then that?
.......lastly, since i need to replace these 2 defective tracks, should i be able to throw that into that very same compiliation and burn it all to the cd?
thanks for any help you can apply!
