Ordering tomorrow! Final check up, please comment
vandy09
Ok so tomorrow's the big day, this is my newegg basket, please double check compatability/make last minute suggestions...
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130072
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220144
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128048
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118004
I'm getting a Samsung 906BW today at Best Buy for $199 (matching circuit city's price). I also already have an antec 900, antec truepower 650W, saitek eclipse2, and a logitech G5. So how does this look? Any input is MUCH appreciated! And thanks for all the help thus far guys!
You may be better off purchasing the Q6600 from clubit.com. Guaranteed OEM G0 stepping. I've heard the Zalman 9500 is really loud. Other than that, you're all set. Good luck! :)
with the promo in that link its cheaper
edit: yeah i didn't see that the latency was different
Thanks a ton guys this helped a lot. I'm changing to the 4-4-4-12 ram and intel cooler (oops). And I have a friend at Microsoft whose getting me Vista for $50, so I didn't list that. Wish me luck!
Yay, it ended up I got Vista Ultimate for $45. Is it worth using the 64-bit version? Or should I just use the 32?
