tuxify
Kinda fits everything in this topic.
First off, with the Antec Nine Hundred: I've heard this case is small, but what else do people think of it? I really like the design, the amount of air flow, and the price is slowly dropping on Newegg.com.
Second of all, I'm having trouble with ATX12V vs. ATX12V/EPS12V. Whats EPS12V? I'm looking at both these 600W PSU:
http://www.newegg.com/product/product.asp?item=N82E16817341001
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341010
I would need to power an 8800GTS, would they both do the trick? And would they both support avid gaming?
And back to the Antec 900: would it be able to support water cooling in the future? I know it has great air flow, and I know it's really small, but wouldn't a strategically placed internal kit or just any regular external kit (http://www.xoxide.com/zalman-reserator-1-v2.html) work?
If you don't think it's possible, or that the Zalman Reserator is a terrible choice, should I consider the http://www.newegg.com/Product/Product.aspx?Item=N82E16811133021 for a good WC case? I know it has a version that has WC pre-installed, but I've heard it's not that great of a system for the price (http://www.xoxide.com/thermaltake-armor-lcs-ve2000bws.html).
Lastly about water cooling. Is building your own kit (each part individually) better than buying an internal kit or an external one?
