Can I Upgrade My HP Compaq Microtower CPU? The current installed CPU is a
Intel Pentium Dual Core E2160 would i be able to install a Intel Core 2 Quad
Q6600. Would the installed motherboard accept this CPU.
Instead of upgrading your cpu, you need to upgrade your GPU. That onboard video really sucks! Since your motherboard has 1 pci-e 16 slot, you can upgrade your video card and get much better performance.
As for upgrading your cpu, I can not tell if your motherboard supports quad cores. I can not find anything saying it can or can't.
Have contacted HP. What GPU do you suggest, i want dual screens. DVI connection would be better.
OUCH! Your system only has a 250 watt PSU, There is not much you can do to upgrade to run todays games. I would be afraid to even try installing a Q6600 in it.
Did you find that PSU info off the support site?
Yes.
Power features
Passive Power Factor Correction (PFC) - with line switch set to 230V - No PFC in 115V line switch position; 90 to 140VAC, or 180 to 264VAC operating voltage range; 100 to 127 VAC, or 200 to 240VAC rated voltage range; 50-60 Hz rated line frequency; 47-63 Hz operating line frequency range; 80-mm power supply fan - variable speed for optimum acoustics; Power Consumption in ES Mode - Suspend to RAM (S3) (Instantly Available PC)
Power consumption
250 watts maximum
Power requirements
Input voltage 90 – 264 / 100 – 240 VAC, 50/60 Hz, 47 – 63 Hz, passive PFC
Is that right that it ill only support certain types of PSU and GPU. how do i know hat will fit.
