HDD Tests
Compatible yes! Worhth the trouble? Not with the complaints heard on Hitachi apparently by several already. Plus you are now going $17- higher over the WD 60gb model posted above. Save on cash and put a better drive in at the same time! Then if you plan to sell or give the portable away as a gift you won't hear complaints about the drive later. :D
that is true! :P
but it wasn't in stock so i was just trying to find something i could get in by the end of the week.
thanks for your help!
i will go with THIS one...
Looks like a good choice here. Of course since I've been using WD drives for the longest time I guess I have a preference for them. :D
