Ok so i have a few problems
1st: i want to run 4GB ram (as this is the amount i got in the deal, and by the time every OS is 64 bit the ram will be redundant)
2nd: i am sick of XP i have copies of XP home and XP pro with all the service packs and even on fresh installs i get the occasional blue screen, the menu's take ages to load if i have cd's in, the explorer dies etc etc
3rd: i am worried that Vista 64 bit will run games slower because most games are still 32 bit.. Am also worried that vista 64 bit will have less compatibility than the 32 bit version even though it can step down to run 32 bit apps.
BUT i guess it will have less annoying crappy bugs than xp (or at least a new set that might be more ignorable)
4th: I am pretty sure that Vista 32 bit will run a bit slower than XP and have less compatibility but will have less bugs, hopefully it will boot faster too, my XP is taking around 4 minutes to fully boot. Also i am pretty sure 32 bit vista can't run 4GB ram which sucks
So i need to know are there ANY other OS options at all?
It needs to support 4GB ram, be a fast-ish operating system with good compatibility that doesn't crash too often and is easy to find drivers for.. does this exist?
This is a gaming pc so Linux etc is out of the question as i want to play: WoW F.E.A.R, colin mcrae, ghost recon and other new-ish games
thx guys
MY new PC is a AM2 6000+ dual core
ASUS m2ne-sli mobo
4 gb corsair 800mhz DDR2 ram
7600gt grafix card
thx guys
ASUS m2ne-sli mobo
7600gt grafix card
