Only 2.8gb out 4gb ram is shown
newgeneral01
I have the p5n32-e sli and recently installed another 2gb to my current 2gb ram. In the windows welcome center it displays only 2.8gb. What happened to the other 1.2gb ?
Yea, you'll have to upgrade to a 64 bit operating system to have that much ram in your system, otherwise the max for vista is 3 gb.
That sounds about right if it's a 32 bit OS, i'm surprised you havent seen one of the many posts saying you cant use more then ~3GB on a 32 bit OS.
thats not correct omega i have 4gb of ram and xp pro and vista 32bit both recognize 3.25 gb, i think the amount of ram seen is dependant on what else you are running with its own ram, i.e. xp 32bit and vista32bit both recognize 4gb of ram but that takes into acount all ram in the pc like video cards and so on the last memory to be read buy the pc is your ram , i could be way off with this so i would like someone who has the correct info to post because this question is a bit of a hot topic just as 64bit or 32 bit vista or xp are hot topics,
So basically your that .75GB of RAM is used in your GFX? :rolleyes:
You lose .75GB with an 32bit, and 64bit can reach 128GB max...
Yes, That .2 is probably being used in in the intergrated graphics, then the other 1gb is not being supported because of the 32bit operating system. If you have 4gb, it is worth it to go to a 64 bit operating system.
How is it not correct? You are saying the same thing I am. The reason he can only see 2.8 instead of 3.2 is dependent on the devices he has installed in his computer.
And you are completely wrong, the 4GB does not include memory from video cards.
Let's fast-forward to the current era. For many years, it's been normal for personal computers to include a Memory Management Unit (MMU). MMUs were expensive add-ons for old computers, but modern CPUs all have one built in. A primary function of an MMU is to allow a computer to have "virtual memory", which in the PC world means "swapping" or "paging" data in and out of however much actual RAM you have as needed, keeping the swapped-out data in a file or files on hard drives. Virtual memory is what allows your PC to have more than 4Gb of total memory, including the swap file(s). Memory management lets the computer augment its physical RAM, and lets programs running on that computer feel as if they've each got a simple solid space of memory available to them without treading on each others' toes. But virtual memory doesn't increase the amount of physical RAM you can have.
The explanation for the three-to-four-gigabyte problems is that modern computers include an arrangement conceptually similar to the old Upper Memory Area one. Many of the original Upper Memory Area MMIO reserved areas still exist today (for backwards compatibility reasons - otherwise you couldn't install DOS on a new PC), and a few more little ones sprouted above 1Mb as PCs went through their growing pains. Those are preserved today as well.
For this reason, a modern "3Gb" computer, which has 3,145,728 kilobytes of physical memory, is only likely to show something like 3,145,192 kilobytes available (look at the Performance tab in the Windows Task Manager, for instance). MMIO ranges "shadow" some of the physical memory, and so the system can't even see that RAM, at the hardware level.
3,145,728 minus 3,145,192 is only a shortfall of 536 kilobytes, though. So this 3Gb computer gives you 99.983% of the memory you paid for. Install more expansion cards in the computer, each of which is likely to eat some MMIO space for itself, and you'll lose a bit more memory. But you'll have to try pretty hard to lose even one whole megabyte. I, for one, am OK with that.
Things get worse above 3Gb.
Large areas of the memory between three and four gigabytes are cordoned off for system devices in exactly the same way that chunks of the Upper Memory Area were purloined in the old days. Once again, the processor (and other system components) can talk with some devices by reading and writing memory addresses up above 3Gb.
The difference is the size of the reserved areas.
Windows users can see all of the reserved memory areas on their PC in Device Manager, using the View -> Resources By Connection option. This is what that view looks like for the PC I'm using now.
The addresses are all in hexadecimal, which makes it less than instantly obvious to the untutored viewer which reserved areas are tiny (and usually old) and which large (and all relatively new). Spend the time to figure it out, though, and you can see the old backwards-compatibility stuff and the new 3Gb-barrier stuff, plain as day.
Hex addresses A0000 to BFFFF, for instance, are still assigned to the video card (a GeForce 7800 GT, in this case). That's addresses 655360 to 786431 in decimal, 640 kilobytes to 768k. This is the old 128 kilobyte reservation for the monochrome, CGA and EGA graphics buffers, still there in case you find your old Leisure Suit Larry disk and want to see if it works.
In the above picture, though, you'll see a much more considerable reservation from C0000000 to CFFFFFFF, that's also assigned to my video card. That's 268,435,456 bytes, equal to the 256 megabytes of memory on the card, and it's the chunk of memory addresses that system devices use when they want to access the card's memory.
If I had a video card with 512Mb or 768Mb of memory on it, it'd take up even more space in the 3Gb-to-4Gb memory map.
And if I were still using an AGP graphics card, there'd be another block of memory reserved for the AGP aperture, used when devices on other buses in the computer want to talk to a graphics card on the AGP bus. I've got a PCIe graphics card, though, which sits on the same bus as all of the other stuff and so doesn't need an aperture.
(If you've got a computer with one of those cheap graphics adapters that uses system memory instead of having RAM of its own, it will of course eat some of your RAM no matter how much you've got installed.)
Power users with a hankerin' for dual graphics cards may be experiencing something of a sinking feeling, at this juncture. Yes, the 256Mb reserved for my little old graphics card means exactly what you think it means: Those two 768Mb graphics cards you can totally justify buying will eat one point five gigabytes of your 32-bit memory map all by themselves, cutting you down to a 2.5Gb ceiling before you even take the other reservations into account.
This also explains why 1Gb graphics cards haven't hit the consumer market yet. Nobody yet needs anything like that much memory on one card for any desktop computer purpose, but some people would still be very happy to pay for such a card just for the pose value. It'd eat the whole of the fourth gigabyte of their system memory, though. And then they'd probably demand their money back.
(This fact has apparently not stopped certain unscrupulous companies, coughDellcough, from allowing people to buy a computer with WinXP, 4Gb of RAM, and a pair of Nvidia's oddball 1Gb GeForce 7950 GX2 cards. Result: 56.25% of the installed memory absent without leave. You might as well have only bought 2Gb.)
As with the Upper Memory Area problem, the 3-4Gb space must have seemed stratospherically far away when people first started buying $15,000 80386 PCs. But here we are running into it, and the result is not pretty.
That was then, this is now. 64-bit CPUs are widely available, and 64-bit OSes are starting to trickle into the mainstream market. The nightmare will, with any luck, soon be over.
A 64-bit PC running a 64-bit OS has a truly vast basic memory address space. The 4Gb 32-bit address space was 4096 times the size of the 1Mb 20-bit space, but the 64-bit address space is 4,294,967,296 times the size of the 32-bit one.
By default, an all-64-bit PC will still have the standard big holes in its memory from three to four gigabytes. This is the lowest-hassle way to deal with the problem - just install more than 4Gb of memory, and live with the fact that your 8Gb PC with a 768Mb graphics card only actually has seven-point-not-much gigabytes of visible RAM.
One advantage of this is that you can still boot a 32-bit OS, if you want to. Another is that this vanilla configuration is most likely to actually work. Cleverer memory configurations aren't necessarily properly supported by hardware and OSes yet.
If you don't care about these factors, though, there are two ways to get the lost memory back.
Some 64-bit motherboards these days give you an option for "memory hole remapping". That moves the fourth-gigabyte MMIO memory holes higher into the 64-bit address space, probably way above the maximum RAM you can physically install.
Many other 64-bit boards, though, are even smarter, and can leave the memory holes where they are and remap (at least some of) the physical RAM out from under the holes and up past 4Gb. This process is often entertainingly referred to as "memory hoisting", and it used to be the preserve of server motherboards. It's been showing up in more and more desktop mobos, though. And on some of them, the memory-hoisting BIOS setting even works, and doesn't horribly crash the system as soon as something tries to use the remapped RAM.
You may only be able to "hoist" the last 512Mb of the 4Gb address space, but that's better than nothing. If it works.
I should add a note about the /3GB, /4GT and /PAE Windows boot.ini switches, too, because they often come up when people are talking about 4Gb-plus Windows PCs.
They are all useless to you. You do not want them.
/3GB and /4GT are config settings for different versions of Windows that tell the operating system to change the partitioning of the 4Gb 32-bit address space so that applications can use 3Gb and the OS kernel only 1Gb, as opposed to the standard 2Gb-each arrangement. They don't help at all with the 3Gb barrier, and most applications don't even notice them, so desktop users lose kernel memory space (and system performance) for no actual gain at all.
The /PAE boot.ini switch, on NT-descended Windows flavours, activates the Physical Address Extension mode that's existed in every PC CPU since the Pentium Pro. That mode cranks the address space up to 64 gigabytes (two to the power of 36), and the computer can then give a 4Gb addressing block within that space - or even more, with extra tricks - to each of several applications.
PAE's no good to the everyday 3Gb-problem-afflicted user, though, for two reasons.
First, it presents 64-bit addresses to drivers, and thus causes exactly the same compatibility problems as a proper 64-bit operating system, except worse, because now you need PAE-aware drivers for 32-bit Windows, instead of just plain 64-bit drivers for a 64-bit OS. From a normal user's point of view, PAE gives you the incompatibility of a 64-bit operating system when you're still running a 32-bit OS.
For this reason, Microsoft changed the behaviour of the /PAE option in all versions of WinXP as of Service Pack 2. They fixed the endless driver problems by, essentially, making /PAE in XP not do anything. All versions of WinXP except for the x64 Edition now have a hard 4Gb addressing limit, no matter what hardware you use them on and what configuration you choose.
This isn't a big problem, of course, since XP is not meant to be a server operating system. But it's still mystifying to people who try the /PAE flag and can't figure out why it doesn't work.
Oh, and just in case you for some reason still wanted to try PAE: It eats CPU time, too.
http://www.dansdata.com/askdan00015.htm
Yeap, thats probable why his is showing up at alittle less than 3gbs instead of alittle over 3 since he has 2 8800 640mbs in SLI.
About dan saying pae eats cpu. It does, but not that much. Many people is running with pae already, because of the dep thing.
It was a bigger deal with windows 2000 but I,m not for sure but I think they changed something about it in XP with SP2
yes, dep support came with sp2. pae is needed to have dep supported in hardware. But in this case, pae doesn't mean support for more than 4G, because xp and vista just ignore everything above this boundary
Ok i get it now, thank you. As long as my games can run with max settings im all good. I upgraded because my comp uses on average a gig of my ram doing nothing. :eek: and i have no start up programs running on aim and basic start up programs. So i thought the gig i have left over sometimes won't cut it for some games.
The regular 32-bit version of Vista and its compatible hardware cannot access a full 4GB of RAM (it's generally limited to around 2.7GB to 3.5GB of RAM). As a result, getting 4GB of RAM for 32-bit Vista is pointless.
tomshardware
does the geforce 8800gts 640 use some of the pc's ram ause i remember going on something and it says the vdeo card has around 1gb
Oke... I am not going to read THAT :eek::P
If that's true, that if you put 4GB that some of the memory will go to your GPU? I don't know that, but if you think about it you'll notice that's a stupid answer. No GPU can afford some extra RAM unless it has Turbo cach or Hyper memory.But, I must say... I saw a 7600GT with 1.5GB. I don't know from where that came from, but I think from the RAM. I even made a topic about that.
Zangetsu
