EEthanShire
A tight squeeze, but looks rather neat.
Hehehe. I like it!
I wonder if the nobs and buttons work on the system. And if the led screen shows the temps and such.
The only thing I would have changed on that is where the cd is. I would not want to have to open the door to change cd's.
That's where you and I differ. I look inside my Antec 900, and I see the Zalman 9700 I installed myself, the AMD X64 FX62 I delicately dropped in, the Asus motherboard I painstakingly screwed into tiny brass standoffs, the wires I painstakingly tucked out of view...
...and I think, My God, I build that thing in there, with my own two hands.
Well just take a look at how many premade cases have swing out doors on those. The last build here was initially a move of everything from one case to one with better air flow with twin doors that swung out. That can get annoying at times when burning data disks and the tray plows those open if a program is set to auto eject.
I differ there! I have a Zalman 9700 on an Asus board inside an Antec 900 slid into the cabinet of the pc desk used here. My concern was keeping temps low in a tight space where the additional 120 in the front and large 200mm fan at the top are a plus along with a good cpu cooler.
The old 939 build upgraded an old Socket case where there was two 80mm fans one rear one top and high board temps. The AeroCool model seen here first saw a large improvement with the 140 on the front plus two 120s added on the side cover. I kept one of those for the side on the 900. http://www.xoxide.com/aerocool-aeroengine-2-black.html
A mni tower case is even more cramped once you try to install anything on besides the basics seen on any micro board. But if you are looking for premade models you go through a ton of those at a few vendors like xoxide.com or like the cube types seen at http://www.directron.com/cubecase.html
I've looked around quite a bit already and have narrowed my choices to the Lanbox Lite, SG01, SG03 and Microfly. However, out of all of those, it seems that the Lanbox Lite has the most room, while still being easy to carry around (and it's the cheapest).
Did you say "carry around"? ThermalTake has a pair of cases with carrying handles included on them seen on the page at http://www.xoxide.com/small-form-factor-cases.html
