I forgot my login password?????
shreddies
I dont know alot about computer for starters, lol, so bear with me, I cant log into my computer because I forgot my password, I need to know a way to login somehow, this is pissing me off, Ive done a google search on how to login without a password and stuff and all of the things that I have found dont work, can anyone tell me a way I can log in without a password?
much thanks
shreddies
I cant login as the admin either because is no icon for it , i dont know what to do
is it against you'r rule because the computer mayby could be a stolen one?!? just asking(im a very curious person).
I have spoken to an Admin, This is all assuming what you are doing is Honest.
Give this a try.
Press Ctrl-Alt-Delete twice at where you type in your password,
This will take you to an administration screen
If there is no password, press enter.
Go to User Accounts, Change/Delete password.
Give this a try.
That's about the only advice we can give you, just one slight correction - one you've pushed Ctrl-Alt-Delete twice you will need to change the User Name to Administrator, and type in the administrators password (if the administrator account has one).
cool, i never knew you could do that. nifty trick, dont know what it could be used for since my admin is dissabled in my comp :rolleyes: :D
Once you have gained access to ur pc, prevent a forgotten password in user accounts > related tasks.
There is other ways such as running in safe mode then changing the password from there. There is also another way that is against the forum rules.
