DavidWright05
Hey guys... I really need help with my computer...
About a month or 2 ago, when I would start up my computer, one of the fans inside would start making a loud noise, but it always stopped after like 10 seconds... Then it progressed to making a really loud noise until I tapped the case. Then it progressed to making a really loud noise until I hit the case, it would come back a little bit softer, then I would hit it a few more times (not that hard) and it would stop. Now it's at the point where I came home from work and it's making the noise. I managed to figure out that it's the graphics card fan on my crappy asus card.... I took it out, used compressed air to blow the dust out, and dusted my whole computer down twice with compressed air... But it still made the sound....
Now I decided to start my asus "pc probe" which gives you the temperatures etc, and it was NOT good... my CPU fan of all things was at 80 degrees celcius... Where I thought something like 50 was the limit... So I shut it down and blew the dust out again and started it up and the reading still said 80. I'm pretty sure it's not safe to operate at that temperature right?
The readings were as follows:
MoBo: 32 C
CPU: 73 C
Chassis Fan: 1200 RPM
CPU Fan: 713 RPM.
ANY ADVICE??? I Really Have no clue what to do...
MoBo: 32 C
CPU: 73 C
CPU Fan: 713 RPM.
