Darth Vapor
oh yeah... do i just change settings in the bios or do I need to dowload an update or flash it?
nevermind - I read the bios upgrade - Im going to need to flash it!
You will need to flash the bios to the newest
http://www.ecs.com.tw/ECSWebSite/Pr...etailid=653&DetailName=Bios&MenuID=46&LanID=0
will it make a big difference?
thinking of making the jump
what do you mean - the cpu specs state it is 2 coresYess... Hyperthreading isn't Dual Core (fyi)
It doesn't have two cores, it has one physical core and one logical core. The logical core isn't actually a "core", Intel created HT to create a logical core with whatever clock cycles arent being used on the actual CPU itself. It increases multi-tasking a bit, but no where near as good as an actual dual-core processor.what do you mean - the cpu specs state it is 2 cores
I was responding to these two posts:The guy went from a single core Athlon to a X2 4200, what does Hyperthreading have to do with anything?
