??Using Logons??
Could you rephrase your question? If you're talking about the Windows logon screen, you can change it in the User Accounts panel.
I think LittleHaiti was talking about modifying the Logon screen without using 3rd party softwares.
Correct me if I'm wrong, LittleHaiti.
For that, you will need Hex Editors.
I suggest that you google for tweaking XP logon screens.
But I'm pretty sure that you will require a Hex editor.
Im not trying to make a logon. I already have the logon file downloaded. Is there a way that I can just switch the current file with the new one?
