ThatGuy16 VIP Member Nov 7, 2007 #44 zer0_c00l said: Any ideas on how to get it better? Click to expand... OC
I INTELCRAZY banned Nov 7, 2007 #45 Pr0 said: 1.4 Click to expand... Have you tried to pull that down any? 1.4v for 3.4Ghz isn't that good.. I have went to 3.8Ghz on 1.4v, I think I can squeeze more though...
Pr0 New Member Nov 7, 2007 #46 I havent tryed to lower it down but i did manage to get the temp at idle 34C
I INTELCRAZY banned Nov 7, 2007 #47 Pr0 said: I havent tryed to lower it down but i did manage to get the temp at idle 34C Click to expand... That's one sign that you could probably go lower... 34*C is pretty good and if it were utilizing all 1.4v, you would think it would be higher temp'd...
Aziek New Member Nov 7, 2007 #48 ZeroCool you didnt score much higher than me and you have the model up. Non OC'ed
Z zer0_c00l Active Member Nov 7, 2007 #49 Aziek said: ZeroCool you didnt score much higher than me and you have the model up. Non OC'ed Click to expand... ic that....we almost have the same system amd and same mobo..you have 2gb's more memory
