i present you with a challenge!! can you handle it?
Here's a bit more gaming oriented list..
1. Powmax MM3800 Beige SGCC Steel Micro-ATX Mini Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811145077 ($13)
2. Biostar GeForce 6100 Socket AM2 Micro-ATX Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138052 ($45)
3. AMD Athlon 64 Socket AM2 X2 4000+
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103774 ($66)
4. Corsair Value Select 1GB DDR2-677 Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146580 ($24)
5. EVGA 7600GS 256MB 128bit video card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130075 ($65)
6. Excelstor 80GB SATA 7200RPM 8mb buffer Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822210003 ($37)
7. Hipro HP-W430PA3 ATX True 400 watt Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817174019 ($30)
8. Masscool 80mm fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835150007 ($2)
9. Sony Beige DVD/CD drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827101132 ($18)
Total (after MIR, w/o shipping): $300
