When I cleaned and reseated the CPU, I did it with it still "locked" into the MoBo, I cleaned it etc without unloocking it. Was this a problem?
HOLY CRAP
Please tell me I didnt just toast my CPU... please god...
Listen: I applied the paste, connected the heatsink like described on via instructions from arctic silver website... But like a total unbelievable idiot I forgot to plug the heatsink back into the mobo... So I start up my computer, notice that the fan is not spinning, and shut it back off after approximately 7 or 8 seconds... I plug it in, turn it back on, but I dont hear a beep and the monitor does not turn on... The CD drive did "initialize" and the GPU turned on, but I dont think that makes any difference.
Did I just toast my CPU? ****
Also, with leaving the CPU in while cleaning it, you run the risk of getting some thermal paste down under the CPU causing a short.
You should always pull the cpu when cleaning it. So pull your cpu and check if there are any signs of any paste under it. You might also have gotten some alcohol down under it.
Yes, it's safe, and yes, more thermal compound is advised.
And too much = bad temperatures...![]()
True. I probably could have phrased my last post different![]()
Yeah, and NORMAL amount is good. (as in 1 dot single core, 1 line dual core)
Did you unplug the system and reset CMOS?
yeah... I even unplugged the PSU from the mobo and took the battery out and let it sit like that for 40 minutes.
Make suer the GFX ain't dead (or use onboard) and try using the basic components... (EX get rid of the Sound card, physics card, ect)
Make sure you didn't spill any TP on the mobo...
