overclocking
does overclocking your cpu make your gpu temp generally higher too?
Not directly, the only way it can make the GPU's temp higher is if the CPU's temp rises as well, causing the air inside your case to rise, and thereby raising your GPU temp. However I wouldn't worry about it, as the difference shouldn't even be that noticeable if you have decent case cooling.
