What do you guys think?
chrislo
Well it has happened again, for the last three days I have been having extremely high ping coming from my Linksys WRT54GS router. I tested directly from the modem the highest ping I got was between 90-120ms at certain times, other times it was between 20-25ms. Thats about normal.
My router though was giving me ping between 190ms-350ms, I tested it wirelessly and wired into port 1 and I got the same ping. That is not normal. On average I get 60-75ms. Right now luckily my ping has went back after getting help from the Linksys tech support.
First thing I he made me do (I don't know how long its been like this) was turn on the MAC Clone Address. According to him this must be enabled if you are using a cable connection. I don't know how long its been like that, might of been like that when I reset the router back to factory specs or since I started to have this problem in June.
After that he made me disconnect the power cables from both the router and modem. Then I reconnected the modem and waited for the modem to get a connection. Then I reconnected the power to the router. Then I did my test and everything was working right.
According to the tech my power supply was probably not constant and it threw them out of sync or something like that. The voltage to the devices wasn't constant and that is what caused the problem. He said I should consider getting a UPS power supply to fix the problem. He said if it happens again do the power cycling and if I still have problems they will send me a new router.
So what do you guys think? You think this problem was caused by the devices not getting constant voltage or something else? I never heard of such a thing happening and I am wondering if the guy is just BS'ing me? Should I get a UPS just for my modem and router? Thanks.
The only reason for cloning your pc's mac address is when your isp recognizes different mac address like when you replace or change your network card. I am on Comcast cable and i don't have mine enabled. If everything was working fine at one time and just all of a sudden changed then its either hardware or software related. But since you have tested your pinging with a different wireless pc then it has something to do with the router i assume. Do you have a friend or relative that has a router that you can try. It also might very well be your ISP.
yes it is very possible. Whenever you are using out of spec voltages it can cause issues with anything electronic. You effectively, rebooted your router and cable modem. Also, MAC address filtering is a security measure, so I am not sure the logic behind that statement.
I don't know anyone else with this router, people I know only have one computer so no need for the router. It's not the ISP for sure because when I was getting high ping from the router I plugged my laptop directly into the modem and got a ping of 20-120ms the average being 63-78 which is what is normal for me.
I never heard of voltage doing such things, I know during the day voltage you get changes somewhat but I didn't think it was enough to throw these devices out of sync. Is a UPS worth my money to solve this problem? The Mac Address I got no idea, according to the tech it needed to be enabled since I am using cable. The other guy that posted has cable and doesn't have it enabled. Maybe only certain ISP's require it?
The ISP only requires the MAC address of your cable modem, and I think that is where the confusion is on that part.
Yes a UPS is not only a back up system but also a line conditioner. It will regulate voltages and protect from sacs and brown outs. Voltages can make a difference. I first discovered this with video I/O devices some time ago. We were using an out of spec AC adapter (it was a 9v and spec was 8v) and the video out would not display properly at all. It had wavy lines and lots of interference. I looked into it and realized I was using out of spec voltages, so I got a spec AC adapter and problem was resolved. It creates line noise when it is out of spec.
I will have to look into a UPS then because I never want to have these problems again.
