How much would this be?
TFB
Someone is selling a pc, and asking for best offer, how much would this comp be.
CPU: Dual core AMD X2 5000+ at 2600 MHZ.
(comes with coppper based 4 heatpipes cooling)
Motherboard: SlI motherboard features Silent Otes cooling (heatpipe),
fully udjustable bios settings and extreme stability. Has lots of USB ports, 2
firewire, 2 ethernet, highdef sound and comes with bunch of cables as well as
with software, manual and extra usb hub.
Memory: 3 gigs of DDR2 pc-6400 800MHZ memory. Low timings (4-4-4-11) with extra cooling (thermaltake) works fine on 3-4-3-8
Video Card: 7900gs 256mb video card
Hard drive: SATA 160gb hardrive - silent
DVD-BURNER
Case: Well ventilated case, green neon lights, 3 fans, great airflow.
PSU: Coolermaster 550W PSU.
Comes with 17in monitor, mouse and speakers etc.
and how much for this one:
Large Antec case - Lots of room to add more hard drives and CD/DVD.
410w powersupply - Ample power for overclocking
Asus DVD burner
160gb Hard drive
3.5 floppy drive - just in case
Creative Live! 5.1 sound card
AMD Athlon 3200+ with Ninja heatpipe tower cooler and 120mm fan
ATI Radeo 9800 pro video card with Zalman heatpipe cooler and 120mm fan
1.5gb RAM
MSI K8T neo Motherboard
comes with original manual
2 SATA ports
8 USB ports supported (6 available)
integrated audio if you dont want to use the Creative Live! 5.1
Windows XP Professional - Legit copy with serial #, orginal disc, license
Second one depends on the "large Antec case". If it's a good case (ie the 900, P180/2's) then it'll cost more as the case costs about $120.
