Heat!
Quentin_T
So, I have a PC that I will be selling on ebay, just the MB/Video/Ram/CPU+Fan.
It is;
Asus A7N8X-Deluxe Rev 2
ATI X700 Pro
Athlon XP +3000
1 GB Crucial DDR 400
Zalman CNPS7000B-Cu Heatsink
It ran pretty cool (never overclocked).
Now my question is, Can anyone tell me which will run cooler? AMD or Intel.
The HTPC case I have is not the best for airflow, so I need something that will out perform the current set-up and run at the same temp.
The current PC is just a bit too slow to play some of the HD movies (8GB+).
Oh yeah, I also forgot to ask about a Sound card that would be the best bang for the buck to connect to my Receiver.
A HTPC.
Here's where I was heading:
BIOSTAR TForce TF7050-M2 AM2 NVIDIA GeForce 7050PV HDMI Micro ATX AMD Motherboard - Retail - 74.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138061
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail - 54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
AMD Athlon 64 X2 5200+ Windsor 2.6GHz 2 x 1MB L2 Cache Socket AM2 Processor - Retail - 119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103759
And maybe just sticking with onboard Video/Audio using the HDMI connection on the MB
