are there any possible way to convert my motherboard to DDR2 RAM.
My PC has Intel 865 motherboard that supports DDR RAM. But now all the new motherboards are coming with DDR2. Wots the difference and are there any possible way to convert my motherboard to DDR2 RAM(bcoz DDR2 comes half the price of DDR).
DDR2 is the new standard. It's getting more and more expensive to make older stuff. Why do you think new things are made? To make more money for cheaper parts of course.
I suggest upgrading to another system/motherboard.
[-0MEGA-];816226 said:DDR3 is actually the new standard, DDR2 has been around since 2003. Both DDR2 and DDR3 offer faster speeds then previous DDR memory, which in turn offers increased bandwidth.
can a motherboard that is made for DDR2 RAM support DDR3 if we put some middleware?
Nope. Even though they both have 240 pins, the divider is in a different spot so you can't install the wrong type. Even if you could, it wouldn't work.can a motherboard that is made for DDR2 RAM support DDR3 if we put some middleware?
+I didn't know Double Data Rate 3 memory also had 240-pin like Double Data Rate 2. That may confuse people in the future. They should have changed the pin specifications so there would be less mix ups. Like we've progressed in the years from 168-pin to 184-pin to 240-pin.
I have heard DDR4 memory is already coming out. Will DDR3 memory be bypassed by most motherboard manufacturers going for DDR4?
[-0MEGA-];818848 said:+
Yup, although DDR3 RAM wont fit in a DDR2 slot because the pin layout is different.
As for DDR4, it's not out yet, nor will be for quite some time. Are you sure you're not talking about GDDR4 for video cards?
