Would call of duty 4 support AMD XP 3200+?
should be fine, thou your temps might hit hard.
Edit: those are the min requirements for cod4
OS: XP or Vista
Processor: 2.6ghz Pentium IV or equivalent (3.2ghz recommended for Vista)
RAM: 1024mb (1536mb recommended for Vista)
Video Card: DirectX 9-compliant Shader 3.0 card with 128 MB of DDR Video Memory (256 MB recommended) AGP 8x or PCI-Express x16
Sound Card: 16-bit DirectX 9-compliant sound card
Agreed. I run an EVGA 8600 GTS (for the moment), and while I can almost max out the settings (except for antialiasing) at 1680x1050, my framerate is pretty crappy. However, I got a huge jump in fps when I turned off the automatic texture option and set everything manually. Don't know why that is.
My rig:
AMD Athlon X64 FX62 (2.8GHz, cooled by Zalman 9700LED)
2GB OCZ SLI Ready RAM @ 800 MHz
Asus M2N-E SLI Motherboard
EVGA 8600GTS w/ 256MB DDR3
Creative Soundblaster Audigy soundcard
WD Caviar Special Edition 200GB EIDE HD w/ 8MB cache
Ultra X3 1000W PSU
Windows XP Pro
My hard drive sucks; I know and accept this. Raptor arrives November 26th, along with Foxconn nForce 590i motherboard.
My 8800GT (on highest settings, res. @ 1024 X 768) does fine, but it runs at 85C!!! (There's no way that's good...) and that's AFTER I put in (hotglued in..) another fan blowing directly on it (which cooled it by 10C)
HEHE keep an eye on that as the glue might melt lmao :eek:
My 8600GTS runs at 79-81*c while gaming, and it's not a problem unless it goes over 90*c. Mine does run COD4 really well though.
Should be great :P
I've been told that my CPU is equivalent to a 2.6GHz... and it literally feels like it! And mines a Sempron... so yours should be great.
I know right! I used to have a Sempron 3200+ 1.8GHz before my current one and I was told by some test that it was worth like 3.2GHz... Is weird but it's all good! :D
niiiice hot glue on an 85C card?
