Greetings everyone,
I have been saving away and got the last of my parts for a new computer build today. I took the day off work, carefully read every manual and installed every device correctly. When it came time to power up, I got two blinking leds on my motherboard but nothing else.
I verified all connections, tried again and got the same result. I first noticed, no fans, hard drive lights, NOTHING was coming on but those two leds on the motherboard. So I disconnected all power cables to where the power supply was not hooked to anything and with my multimeter, I verified that NONE of the 4 pin connectors coming from the PSU had power. The only place I can read power is on the 20 pin main motherboard connector.
So to me, it appears my power supply is DOA. Would that sound logical?? Is there anything else I can check? I mean, if I plug a 4 pin power connector directly into a 20mm fan, shouldn't it begin to spin? The main 20 + 4 pin connectors do not have to be connected for the 4 pin connectors to get power do they?
I am very upset as all the stores that would sell a PSU are closed now and will be tomorrow as well. I bought this PSU online from a respectable merchant and I am sure I can get it replaced, but I am not going to sit around and wait till that happens. I will go out first thing on Friday and buy a new one and then sell the one I get replaced from the company. That is unless someone thinks this can be something else??
I would imagine all of the power supply cables should have a constant DC output but maybe I am wrong. Below is all the components for reference
* VGA nForce 680i SLI Motherboard w/ Intel Quad Core
* ASUS Arctic Square 92mm Vapo Bearing CPU Cooler
* VGA EVGA 640-P2-N829-A1 8800GTS640M
* 4 Gb OCZ Platinum RAM
* Cooler Master 650 W PSU
* Cooler Master Cosmos 1000 ATX Full-Tower Case
* Lite-On x 20 DVD Burner w/ light scribe as primary
* Lite-On x 20 DVD Burner w/o l.s. as secondary
* Seagate 7200 16mb 500 GB
* Western Digital Caviar SE16 WD7500AAKS 750GB 7200 RPM
* Koutech IO-RCM620 USB 2.0 3.5"/5.25" Card Reader
Thanks in advance
Thanks in advance
