Case Mod Questions
wow that fan moves lots air, it will adhust automatically, but to stop this you could cut the yellow/white wire (which is the sensor wire) and then it should run at full speed, or plug it into a PSU or fan controller and not a motherboard
HEHE no none since i screwed my old case, my new case hasnt been touched (its nice 'n tidy inside :)), but i have a switch i need to mount somewhere.
Also im doing a mod this week or next for a HDD guage, an analouge meter with a small pin with moves when the HDD is active, along with 2 white LED's ill post up pics etc... when its done :)
lol, I know, I wouldn't want to screw it up either! :P
What kind of a guage, I get what you mean, but I don't know what it'll look like?
White LED's? Where are they going?
Nice find, Taylor. If I had a little more confidence with my wiring and soldering abilities, I might try that. As it is, I'll keep it for later. Thanks.
Somehow though, my CPU has decided to put itself back to stock? Ahh well... May be getting some more RAM soon anyway :P
Pictures on the way! :D
It was very loud, now it's just loud, I've set the rear fan to half speed to reduce the noise :cool:
looks alot better dan i like it,Shame its loud though:cool:
are those two fans on the side of your case on full speed all the time?
Yeah, looks alright, slight drop on temps too :P
Yup, plugged straight into the molex connectors, so 100%...
Ive got a 41 DBa fan on mine, i know what your going through, but you soon get used to it
These two are 44DB each! :cool: lol!
I hope so you know, I thought my last one was loud too! :P
