I want my resoulution bigger but when I do the writing is weird and its hard to read it
Are you using an LCD monitor? If this is the case you may have to visit
http://www.microsoft.com/typography/cleartype/tuner/Step1.aspx
in Internet Explorer (will not work in Firefox).
And turn on ClearType and see if that helps.
If you're using a CRT monitor, the text is probably just too small to read.
Wait, you want to see the words bigger or smaller?![]()
just hit control and scroll your mouse wheel.
down makes text bigger, up makes it smaller.
works on most text. great for when reading forums.
