[-0MEGA-];822424 said:In short, if it's a pre-built computer from a retail manufacturer, then you are out of luck.
Resetting the BIOS does absolutely nothing other then revert everything back to defaults, are you sure you're not talking about re-flashing the BIOS with a hacked BIOS?TrueBut some prebuilts can get OCing abilities by resetting CMOS... (since manufacturers block it)...
And some might be able to get over it with a CMOS flash... Who knows?![]()
[-0MEGA-];822479 said:Resetting the BIOS does absolutely nothing other then revert everything back to defaults, are you sure you're not talking about re-flashing the BIOS with a hacked BIOS?
Well that "someone" doesn't know what he's talking about. He is right in saying that the manufacturer does lock out any overclocking abilities and advanced tweaking options, but "resetting" is the wrong word. Resetting it by clearing the jumper or other means will just revert everything to defaults, but will NOT unlock any options.No, before I'm 100% sure that someone posted on CF saying that sometimes manufacturers block the OC option out, but you un-block it by resetting the BIOS.
[-0MEGA-];822503 said:Well that "someone" doesn't know what he's talking about. He is right in saying that the manufacturer does lock out any overclocking abilities and advanced tweaking options, but "resetting" is the wrong word. Resetting it by clearing the jumper or other means will just revert everything to defaults, but will NOT unlock any options.
Interesting. Another thing to erase from my mind![]()
Don't believe everything you read/see.
