djjimmy2k2
hey. im trying to OC my 7900GS. ive never done it before so i thought id have a go at using a simple program like ntune to do it. i heard that ntune only works on nvidia mobos but that giving it a go wouldnt do any harm, just that if it didnt work it just wouldnt raise the values.
so last night i upped the GPU from the stock 450/660 to 500/690. i only did that bit because i found a thread on another forum by someone who did the same. anyway it worked great and raised my framerate in unreal tournament 3 from an average 25fps to 28fps. thing is, i had a look at the performance stats in nvidia monitorview and it said that the core value hadnt gone up and was still running at 450 rather than the 500 i tried to OC it to. and then i come back to the pc today and both values have been reset to stock. is it that ntune wont work properly cos i havent got a nvidia mobo or is it something else?
can i expect rivatuner to not make any difference or should i give it a go? if i OC my GPU will i have to change any other values, like for my fan, or can i get it up to a certain set of values without having to change anything else? if so what settings can i get it up to without changing anything other than the core and memory values?
thanks for the help.
P.S. i have a dell pc, which apparently are all but unoverclockable except for the GPU.
