Question about a eSATA/USB 2.0 Drive
Gasparovachi
On the motherboard I'm going to buy, there are 4 SATA connectors on it. Since my current HDD isn't very big (80GB) I decided to pick up a external drive.
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130129
Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136081
eSATA to SATA Cable
http://www.newegg.com/Product/Product.aspx?Item=N82E16812200092
-Will all this stuff work together?
-Why are the SATA ports on the mobo inside? Will I have to take the side off to connect it?
-Will this transfer files fast?
-Will I be able to put my games on it, and run it from the desktop with a shortcut?
-Will this drive work with Vista?
-Gasparovachi
I would imagine it will work.
Is there any reason you don't want to get a second internal hard drive?
For seeing the exact same capacity you can save quite a bit on an internal model like seeing $75 for the OEM price at http://www.newegg.com/Product/Product.aspx?Item=N82E16822136109
If you are not plannin to lug the external drive around from copying file back and forth between machines the $109.99 price seen on the 500gb sata drives here is now seeing a holiday special of $94.99 at http://www.newegg.com/Product/Product.aspx?Item=N82E16822136178
Alright, thanks :)
With another internal HDD won't it appear in my computer and you can just access it there?
Once you have the second drive installed you have a few options for seeing it partitioned and formatted to be available for use. Some like myself prefer a 3rd party program for performing that task like GParted here. That's a free Linux drive tool where only a few work with MS type partitions.
The fast and easy method is simply to use the Disk Management tool already included in Windows. With XP and Vista that option is found in the Control Panel>Administrative Tools>Computer Management>Storage section there. A good reference for that is seen at http://support.microsoft.com/kb/309000/ and for general use of the Windows installer http://support.microsoft.com/kb/313348/en-us
To see just what the tool looks like and understand references here, http://www.theeldergeek.com/disk_management.htm
You access internal and external drives by going to my computer. Yes an internal isn't as easy to move to another PC and if that's what you mean and if that's the case, external is the way to go.
