what program is the one im looking for
xxxalpinexxx80
Hi, i cant remember what name its called, but i know some people use it here, it is that software that some one has in there sig help for mankind , and it uses multiple computers instead of 1 computer, and like we have a number for a score? can some one remind me and provide me a link
also one dude said the program likes quads
so if i leave my computer on 24/7 i wouldnt mind helping ppl
xxxalpinexxx80 since you have a quad core. you'll want to properly utilize to run F@H at home correct? You will need the SMP F@H client to do so. Which you can get here http://www.stanford.edu/~kasson/folding/Folding@Home Windows SMP Client.EXE and you will need to follow these instructions http://fahwiki.net/index.php/How_do_I_install_the_SMP_Console_client_in_Windows_Vista? This will require that you set a password for your user account before you run the "install.bat" file, just a heads up.
right now im gonna finish hw so i will do it corectly tomaro, but would it work to its full benifiets if i donwload the first link and just enter the code and run
No, as it is a single threaded client, meaning it will only utilize one core fully. The SMP client is the only one that is multi-threaded for dual and quad cores. It is really simple actually. The install instructions just overcomplicate it.
