You can use the 9200 in Vista, although you wont have the 3D and Aero effects.so since the 9200 doesnt support dx9 it wouldnt work on vista premium or what. so how much ram would it take to boost the intergrated to 256 and than how much ram would i need to make it adequate for gaming. I might not even use it for gaming the computer has either a 1.6 ghz celeron or 1.6 ghz duo core. Is a 2.7 ghz celeron better than the 1.6 ghz duo core? or no
I would only set it to 256MB (via the BIOS) if you have at least 2GB of RAM. Now the x3100 is an integrated card so 128MB is plenty, now for gaming neither one will be able to play the newer games, although some older games should run on lower settings.ok the processor is a Intel® Pentium® Dual-Core Processor E2140 1.60GHz, 1MB L2 Cache. Ok so for the intergrated how much memory do i need for 256 mb max and enough to run a game. I couldnt imagine doing much gaming becuase i have an xbox 360. So i want the vista visuals so i might use intergrated but how much ram will i need. And i fi max out the intergrated will it be better than the radeon 9200?
Yes all of the RAM for the x3100 is shared with the system RAM, so it will take away from it.yes but does the intergrated only share 256 mb of ram or it doesnt work that way. Also i want vista visuals so i might need the intergrated. But if the intergrated it maxed out wouldnt it be better than the radeon 9200
