Thank you. Does this tell you what you need to know:
Specifications
Product
Aspire T180
Language
English
Model
Aspire T180 Specifications
Specifications
Processor
AMD AM2 Athlon 64 x 2 or Athlon 64 or Sempron (940 pin)
Cache
depending on the CPU
Memory
256MB DDR2 533/667/800 SDRAM expandable to 4GB
BIOS
Flash BIOS
Supported Protocols
ACPI 2.0, APM 1.2, SMBIOS 2.3, WFM 2.0, ASD 1.03, PXE boot ROM, PCI 2.3, DMI 2.0, WOL, Bootable CD-ROM 1.0, USB 1.1~USB 2.0, E-IDE (up to PIO mode-4), ANSI ATA 3.0, ATAPI
System Chipset
nVidia MCP61S + MCP61P
I/O Controller Hub
ITE8726
Expansion Slots
1 PCI-Express x16 slot
2 PCI v2.3 slots
Audio
Integrated nVidia MCP61 with AC97, ALC888 codec supporting 16 bit PCM format for 7.1 Channel High Definition Audio codecs with UAA (Universal Audio Architecture)
Speakers
Optional on selected models
Video
PCI Express x16 Add-on card (selected models)
Storage
3.5" 1.44MB Floppy Disk Drive (selected models)
CD-ROM, CD-RW, DVD-ROM, DVD/CD-RW Combo, DVD-RW, DVD+RW, DVD Dual, DVD SupermultiPlus (varies by models)
Up to 400GB Hard Disk Drive SATA (varies by models)
9 in 1 Card Reader (selected models)
Modem
Networking
Integrated Marvell 88E8056 Gigabit (RJ-45 LAN connector)
Ports
Rear: 1 PS2 Keyboard port, 1 PS2 Mouse port, 1 Serial port, 1 Parallel port, 2 USB 2.0 ports, 1 VGA port, 1 IEEE 1394 port, Audio line in, line out, headphone out, Microphone in
Front: 2 USB 2.0 ports, 1 headphone out, and 1 Microphone in
Environmental
Temperature:
Operating: +5oC ~+35oC
Non-operating: -10oC ~ +60oC
Relative Humidity:
Operating: 15% - 80% RH Non-condensing
Non-Operating Storage: 10% - 90% RH, Non-condensing at 40° C
Maximum Vibration:
Operating: 5 ~ 16.2Hz: 0.38mm (peak to peak) 16.2 ~ 250Hz; 0.2G
Non-Operating Storage: 5 ~ 27.1Hz: 0.6G 27.1 ~ 50Hz; 0.4mm (peak to peak) 50 ~ 500Hz: 2G
Chassis
Desktop, 7.2" (183mm) W x 17.9" (445mm) D x 14.6" (370mm) H
Power Supply
Industry Standard 250 Watt
Operating System
Windows XP Professional with Service Pack 2
Windows XP Home Edition with Service Pack 2
Windows XP Media Center Edition
Linpus Linux console version
(varies by model)
