zeppelin03
I'm about to build a new computer. If i uses an old harddrive that has windows on it will i need to install windows at all or will it be fine
Who says you need to reinstall windows?
I basically swapped a whole computer, and kept the same boot Hdd with windows on it.
It's not that hard. Just go through your device manager and uninstall drivers/remove everything you can. It certainly takes a while for the new system to install all the new drivers, but mine works perfectly.
This is for XP anyway. You didn't specify your OS![]()
I have discs to reinstall Windows Xp from an old dell computer could i use that or would i have to buy a new one
