Vista & XP on same driver problem
JamesBart
Hey Guys,
On my Asus Notebook i want to install XP and vista. The idea being that Vista would be on 20gb of ther hdd and xp on 60gb as its a 80gb Disk, well its more 77 you know how it is.
so i loaded the XP disk and partitioned the drive to the 20/60 divide that i wanted.
i wanted Vista on the first 20 and than XP on the 60.
so i insert the Vista disk and install Vista, no problems at all. i think finalyl get it all loaded up and i know have vista. i check in My computer to see if the other partition that i created is there and its not.
so i then go to computer management>storage and create a partition for 28gb as thats all it would let me do.
so this is where its starting to go all wrong... oh the joy.
i then decide i'll settle for this even though its not what i really wanted.
i then install XP on the second partition and when it was loading drivers etc and was about to complete it asked me to remove the XP disk. i done this and when the computer rebooted it said "error loading OS" so it wont load either Vista or XP.
where have i gone wrong and what can i do to resolve this?
thanks in advance guys :)
just hope to get it sorted :)
any question etc then please just ask :)
I don't really understand this, some1 will possibly, but what did you mean with that; Did you mean to create two accounts on notebook or just two partitions with different Operating Systems?? Because I didn't know that you can do the last thing...
I would start over and install XP first. You see, if you install Vista after XP, Vista will automatically create a boot menu for the XP installation. There could be a number of reasons for the "error loading OS" problem. Or you can try running a repair w/ the Vista DVD. If it's a simple boot loader problem, Vista will create a boot menu for the XP installation.
thanks mep916 i'll give that a go. i think i'll try and do some form of repair and take it from there.
The one thing that i hate about Vista is it takes ages to install :(
best get to work then :)
thanks again and i'll keep this thread updated :)
Well i tried recovery and that hasnt worked so im starting from scratch and XP is now installing :)
That's odd...I've noticed that Vista installs much faster than XP.
hmmm could that be computer related or OS related? i think i just have no patience :)
Good Luck!
thanks im going to need it :)
If the repair with the Vista DVD doesn't work, post you're specific problem(s). You don't want to reinstall both OSes unless you absolutely have to.
oh Dear ive just started to install Vista and this is the the error i have got, i want installing on partition 2 of the hdd
ERROR:c [err=1117]
anyone had this before and know what i should do?
Thanks
