Stopping boot messages on SuSE Linux
Slipstream
Hi,
I'm having fdisk failures at boot, but I can't see where the problem starts because the boot messages scroll by too fast. Is there a way to scroll back upward---or even to stop the boot process---so the messages can be read?
Thanks for any replies!
look into your log files under /var/log typically (may be slightly different) and then copy/paste any messages that could help us figure it out.
if you need help, go to terminal and type this
Code:
ls -al /var
that will list all directories under /var. I can't remember off the top of my head what exact directory they are in, but if you copy/paste the results of the ls I can navigate you through.
Ok, I finally got some of this stuff figured out---in particular, how to read the files!
The only one I could open is /var/log/boot.msg. Nothing seems out of place, until it stops at lines:
Skipped services in runlevel 3: nfs nfsboot
<notice>killproc: kill(4274,3)
Seems like all the /dev/md still exist. But the file systems don't get mounted. I guess that happens after runlevel 3. Could this be mechanical failure?
I finally figured out how to read /var/log/boot.msg. Nothing seems out of place, until it stops at lines:
What could this be?
Yes, I did that. There's nothing obviously wrong. It stops at runlevel 3, like I stated. Nothing more to report.
Just wish I could scroll upward through the actual boot messages to see where it all begins. I don't think it's all being logged.
try
cat /var/log/boot.menu head -100
That will print the first 100 lines of the log file, but I doubt its that big...
can you boot into run level 1? and run a fsck?
The file doesn't exist.
No, there's a problem with some module. I can't even login as root user.
I'm about to order a copy of Windows, but I'm still hopeful that this is hardware related...if that's something one can be hopeful about :-/
Formatted and reinstalled? Only about once every month or two, for the past year. Until recently, I've been running x86_64 SuSE; this is my first attempt at 32-bit.
The x86_64 caused lots of problems due to needing 32-bit libraries for certain apps. So now I decided to forgo that mess, and just run 32-bit. I guess it doesn't work either.
by the way, I ran memtest overnight; so far no errors. I also did a surface scan of all disks, which included a write test; no errors.
what OSes have you tried? Perhaps you have a rare configuration that is not supported?
Or, perhaps you do have hardware failure somewhere. Very strange issue you have.
