Is this ram compatible with my pc?
durrutti
Hi,
I'm looking to add ram to my pc (Hp pavillon t546.fr) if I'm not mistaken the motherboard is an Oxford with the Intel 848P chipset. I want to buy this ram: 1 G DDR400,
184 PIN Memory
3.2 GB/sec
400Mhz
2.5 / 2.6 Volt Module
DIMM (DUAL IN-LINE MEMORY 128 X 64) HIGH DENSITY
Non-ECC, Non-Parity
Unbuffered
Will it be compatible? I looked around but cant figure it out
Thanks
Yes it SHOULD work... But we need your MODEL, not your chipset. There can be tons of motherboards with the same chipset but with different memory types..
Ok sorry about that when i check it says ASUS P4SD-LA, also here's what they say regarding memory:
Memory Type DDR SDRAM (Supports duel channel)
Memory Speed PC3200 (400 MHz),
PC2700 (333 MHz),
PC2100 (266 MHz)
Memory Sockets Four DDR DIMM (184-pin)
thanks for your help
edit: what worries me is the High density, would that be a problem?
