virus all folders 180KB and exe
raviverma
Hi,
Somebody please help me out. I am facing a virus problem, I will outline the sympthoms:
1. All folders are converted into exe extensions.
2. All folder size becomes 180KB
3. Task Manager Disabled.
4. Registry Disabled.
5. Administrative rights are disallowed.
6. Folder options is missing.
7. Systems keeps on restarting sometimes.
8. on double clicking any folder it doesnot open.
I thaught it was brontok virus, and used brontok removal tool from bitdefender, it was useless this time.
Kindly, suggest me something,
Regards,
Ravi
The only solution possible it'll be reformating or using a cd/dvd recovery other than that there is nothing you can do when stuff starts changing
yup, as chupacabra said... you need to do a reformat...
just put in your windows CD in the CD drive and change the BIOS menu to boot from CD drive instead of hard disk and then follow the instruction from there onwards...
