2 questions,
first is, If I buy the Antec 900, will I need any other fans?
If so, what if all my fan necessary products were retails so the fan comes with them, would I still need other fans?
Second question is, Why is everyone telling me that it is ahrd to work around with the Antec 900? Their saying thtat it is hard to put stuff in and stuff, is that correct?
Thank you
Yes, get all new 120mm fans. Replace the existing with Nexus fans. The stock Antec fans are noisy and do not have the best air flow. The Nexus fans are much quieter and have better air flow overall.
http://www.xoxide.com/nexus-120mm-fan-black-white.html
The Antec 900 is hard to use. The power supply sits on the bottom of the case, and most motherboards are designed for PSU's that sit above the motherboard. So the placement of the PSU in the 900 leads to some problems running wires to the different connectors.
The 900 comes with an optional mount for a fan that installs on one of the drive cages, but if you use it, you can not install anything inside that cage because the fan would block any wires coming off the drives inside of the cage.
The drive cages that come with the 900 are very poorly designed. Nothing in this case is tool less, and the drive cages are the worst. You have to use non standard screws to mount the drives inside the case (the screws are about an inch long) and if you happen to turn the cage upside down and then install the drives, you will have to remove the drives and reinstall them because the drive cage only goes into the case in one direction.
The front case screens are very easily knocked out of place, resulting in taking off both sides of the case to adjust them.
There is not much room inside the case at all for running wires, you can run them on the back side of the motherboard to hide them as much as you can. But even then there is not much room.
The 900 has great potential, but it needs some redesigning to make it a great case.
