Interested
Should i wait until January for the prices to drop (Intel 45nm) so that i can build a new computer, or should i just build one now?
yea...i think i will wait....whats better, a 45nm core 2 duo (like e8x00) or just get like a q6600?
Does Cache really matter?
Yes! Cache really does matter. It can make huge differences in performance. It can save massive amounts of processing time during RAM refreshes (which happens every 16ms on DRAM)
I would say just wait a little bit longer. Obviously, there is always going to be something better out there and something newer coming out. However, in the first quarter of 2008, Intel will be releasing the Q9770. Why not wait a little bit, get the newest CPU, and have the best for just a few months?
whats more future proff, q6600, or e8400?
I would say the E8400.
i think q6600, bc its quad, which is the way of the future.
whyd you ask the question then if you knew the answer. I say the dual core because there are going to be better quads out and by the time the software utilizes all four cores the q6600 will be obsolete and there will be better quad cores out by then.
