Building Comp for xmas Check it out! Tell me what I should change!!
ran4it2
Can you guys look over this and tell me if I forgot anything or if any of the stuff I chose is bad. I didnt include speakers,mouse,keyboard and monitor b.c I already have them.
Thanks alot
i really dont play games much anymore
all i do is basic stuff i just want a faster rig that can play games on max setting and everything without lagging
16MB Cache HDD.
Western Digital Caviar RE WD1600YS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM $60
Budget Case: COOLER MASTER Centurion 5 CAC-T05-WW Black/Silver Aluminum Bezel, SECC Chassis ATX Mid Tower Computer Case - Retail $40
Better GPU:
SAPPHIRE 100216L Radeon HD 3850 256MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready CrossFire Supported Video Card - Retail $170
By the way, when comparing with 8600GT, I prefer 2600XT as it is HDCP ready.
i put the round cable for my dvdrw and cd rw drives
as for my budget im trying to stay below $700
i like the case so thats staying and the video card seems good b.c i dont play games very often and its not going to be put to use that much
'all i do is basic stuff i just want a faster rig that can play games on max setting and everything without lagging'
with that video card you wont be able to run games on max settings smoothly unless they are aged games
