arggg:( help please!!!
InFlames_44
hey guys.i started up my pc this morning and for some reason it just keeps going through the startup and wont load windows.
ive tryed booting with a cd that is bootable and set my boot priority in the bios to no avail.
what do i do guys? i need a hand
you need to complete a repair installation of windows, if you watch carefully do you see a blue flash on the screen and then it starts rebotting again? if so, it's likely either you or a dodgy program has inadvertently deleted some system files.
A repair installation should fix it
im almost positive that was the problem.i was doing some cleaning yesterday.and im pretty sure it deleted some os files
repair disk thats a different disc correct? if not how do i access it?
There is an option to repair a Windows Installation on the Windows CD. Simply boot to the CD, let it load, and select the option to Repair rather than Reinstall.
thats the problem though.it tells me to press any key to boot from cd.and it doesn't boot into the cd.it just starts over.
Ahhh. Does any part of the Restore CD work (ie, load up, do some stuff, then reboot) and then you get that message again? Or is it a 'turn on the system, boot to CD, then it reboots' issue?
earlier there was no blue screen, then i did a fresh install and i get a blue screen.
im gona try a repair.if that don't work
... reformat:mad::(
